I have purchased the board ZCU106, but there aren't any example included and not even online (at product page).
Where should I search for it?
also, I have a license of MIPI IP core but the example design will only for ZCU102 as shown in the picture below. there is no option for ZCU106. I want to use this IP on ZCU106, please suggest how should I proceed ?
Re: ZCU106
Hi @msh,
You might want to contact AVNET and ask them for the availability of a TRD on ZCU106.
For the UHD-SDI example check the chapter 5 of PG290.
In fact there is also an example design for HDMI. Check chapter 5 of PG236.
But note that these 2 example designs are using baremetal application and not linux.
Florent
Re: ZCU106
Hi @msh,
One example design which is publicly available for ZCU106 is the UHD-SDI.
You might want to contact your FAE for more designs.
Florent
Re: ZCU106
I have got the board from Avnet.
It was strange that there is no CD along with the board, hence no TRD.
There are some TRD available online for ZCU102 but their source is only on the CD. Therefore I cannot download from anywhere else.
Is it possible for you to direct me to the UHD SDI example?
Re: ZCU106
Hi @msh,
Florent
