ZCU111 Board Support Package missing recipes.
Hi all,
It would appear that the board support packages xilinx-zcu111-v2018.3-final.bsp and xilinx-zcu111-v2018.3-final.bsp are missing the associated recipe files for the rftool, rfdc and rfdc example.
I have read the solution posted at
https://forums.xilinx.com/t5/Embedded-Linux/Missing-edits-for-PetaLinux-2018-2-for-zcu111/td-p/910188
But have been unable to locate the recipe files.   I think the solution is suggesting copying the compiled files in a pre-built version on to the built target.  If this is the case then this is a workaround and the recipe files need to be added to the associated BSPs.
Walter
Re: ZCU111 Board Support Package missing recipes.
I think I now understand the confusion.   I think it is down to a tale of two bsps.
The recipes are located in the  rdf0476-zcu111-RFdc-eval-tool-2018-3.zip reference design in the rfsoc_petalinux_bsp.bsp located in the rdf0476-zcu111-RFdc-eval-tool-2018-3/apu directory when you unzip.  The one that should be used for the trf is rfsoc_petalinux_bsp.bsp
I have been using this xilinx-zcu111-v2018.3-final.bsp which is the referenced link at the Petalinux download.
The confusion is that both bsp target the same board, but are not the same.
Hope this helps
Walter
The RF Data converter evaluation design ug1287 design files come with the BSP for the evaluation setup. The recipes for the rftool is in this BSP
Hope this helps
Walter
