Observer paulburnsuk
ZCU111 RF Data Converter Eval design generates VDMA errors on large DDR captures
I have a ZCU111 RFSoC Eval board, running the pre-built 2018.3 release of the "NON-MTSDesign_8x8" images from SD card. Everything seems to running OK when configured in BRAM mode, and when I switch to DDR mode I can increase the capture size to 2097152 samples without issue. But if I attempt larger capture sizes I see DMA errors appearing on the RFSoC console:
 xilinx-vdma b000a000.dma: Channel ffffffc87ad86418 has errors 10, cdr 15964680 tdr 15974400
This is using the default sample rate (3194.4 MHz) and ADC Tile 0 configured with the Mixer disabled (Real-mode). I've tried various decimation rates down to 8x - so the effective output rate is ~400MHz real-only. I'm capturing on only a single ADC channel (Tile 0 ADC01).
According to the documentation the design should support single channel ADC captures of up to 128MB @ 4096 MHz but I don't seem to be getting anywhere near that. See https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/57606309/ZCU111+RFSoC+RF+Data+Converter+Evaluation+Tool+Getting+Started+Guide#ZCU111RFSoCRFDataConverterEvaluationToolGettingStartedGuide-AppendixAPerformanceTable
Shorter captures (up to 2M samples) do seem to be robust and I can capture multiple complex channels and simultaneously output complex DAC waveforms without error. It's only when attempring long captures that I see this problem.
Any suggestions as to what I might be doing wrong?
Paul
Visitor desaic
Re: ZCU111 RF Data Converter Eval design generates VDMA errors on large DDR captures
I have encountered exactly the same problem! Do you have a solution? Otherwise let's hope and pray.
I have a service request in. WIll update when I get a response.
Paul
I'm also seeing this same issue with larger capture size.  We're suspecting the issue is related to the rftool application code, in data_interface.c,  ReadDataFromMemory_ddr.   From the 18.3 verison of this file . . .
/* Trigger DMA */
ret = read((info.fd_adc[adc]), &adc_chaninfo,
(((adc_chaninfo.channel_size[0])) * sizeof(signed char)));
The &adc_chaninfo doesn't make sense to us.  Below is the same code from version 18.2.  There are many changes in data_interface.c between 18.2 and 18.3 so it's not suprising that this line is different, but we're wondering if the updates were made correctly to this line.
/* Trigger DMA */
ret = read((info.fd_adc[adc]), info.map_adc[adc],
((size + (512 * 1024)) * sizeof(signed char)));
