Zedboard standalone SD card read & test program fails
I am trying to using standalone program to test the SD card read and write speed, the program is as follow
   // SDIO Controller Test
   static XSdPs ps7_sd_0;
   XSdPs_Config * SdConfig_0;
   u8 RxBuffer[512*2];
   int Status;
   SdConfig_0 = XSdPs_LookupConfig(XPAR_PS7_SD_0_DEVICE_ID);
    if (NULL == SdConfig_0) {
        return XST_FAILURE;
    Status = XSdPs_CfgInitialize(&ps7_sd_0, SdConfig_0, SdConfig_0->BaseAddress);
    if (Status != XST_SUCCESS) {
        print("Sd Config failed !\n\r");
        return XST_FAILURE;
    Status = XSdPs_SdCardInitialize(&ps7_sd_0);
        print("Sd0 Initialization failed !\n\r");
        return XST_FAILURE;
    // read and write test
    Status = XSdPs_ReadPolled(&ps7_sd_0, 0x01, 0x01, RxBuffer);
        print("Sd1 Read failed !\n\r");
        return XST_FAILURE;
The board is zedboard rev c with vivado 2013.4.
The last read function fails, anyone knows why ? Thanks.
Re: Zedboard standalone SD card read & test program fails
Hi doony,
You can find a detailed tutorial with source code on how to use the SD card on a standalone SDK project targeting the Zynq7000 (Zedboard ) on this link http://embeddedcentric.com/data-logging-using-sd-cards/
Ali
