Observer mnanoop2014
Zynq Ultrascale+ ZCU102 embedded design Tutorial (UG1209) petalinux build failure
Hi all, I've been following the UG1209 Embedded design tutorial for Zynq Ultrascale+ (ZCU102 Evaluation board) (link).
Using Ubuntu 16.04 (not Virtual) with 16 core Intel Xeon, 64GB RAM. Vivado 2018.2 and Petalinux 2018.2.
I am able to generate the HDF file for just the zynq processor in the design and build linux images successfully for it.
But when I also add AXI timers, GPIOs and generate HDF successfully and then try to build new Linux in Petalinux the following way:
petalinux-create -t project -s <proper BSP>
petalinux-config --get-hw-description=<path to new HDF>
(select SD card and save config)
petalinux-build
It fails to build PMU f/w or FSBL. The build log says errors in files in <include> folder for FSBL and PMU f/w and when I check that, I realized those header files are not copied fully or are not copied at all. Some files have missing #endif and some files have missing declarations. I verified with the corresponding files of the earlier Linux build and they have all the files in full.
I tried redownloading BSP packages from Xilinx, tried different BSP packages, tried regenerating HDF again, tried with Petalinux 2017 and the issue remains.
Am I going wrong anywhere/missing something? Any help would be appreciated.
TIA
Anoop
