Visitor kobay000
Zynq ZC702 & XADC
Hi, I'm new with Zynq devices and XADC. So, i need to measure 6 different external voltage sources (3 current & 3 voltage transducers actually) simultaneously in a project. Could it be done with ZC702? It is really confusing when i look user guide. It says that only 1st and 2nd pins (VN & VP) of J40 are the dedicated analog input channels for the XADC. So that means there is only 1 ADC? If so, how can i reach my goal? Any help would be appreciated.
Re: Zynq ZC702 & XADC
zynq has additonal auxiliary analog inputs.
Visitor kobay000
So, it can be done without using extra board (Analog Multiplexer etc.)? I mean MUX representation in UG480 is just informative then?
Hi @kobay000
There are no Separate ADC's for on chip temperature sensor , Supplies and Auxiliary inputs.  As your objective here is to monitor 6 differential analog inputs
1. You have to connected it to top level of the design.
2. Assigned/locked it to associated pin location.
3. Enable Channel Sequencer through XADC wizard and enable 6 channels as shown below  [ Configure the XADC registers as per your requirement (page 42 of UG480) if you are instantiating XADC Primitive ]
Note :  Some auxiliary analog channels might not be supported in certain  Zynq-7000 AP SoC device package options. you should consult the package file for the device.
Reply if you have any queries, Give Kudos and Accept as Solution if you get the resolution.
Visitor kobay000
Do i need to buy analog signal multiplexer card? Also connect it to which pins?
