hardware acceleration using KCU 1500
Hi ,
I have recently purchased the Kintex Ultrascale KCU 1500 acceleration board. My project is to accelerate a custom software application in Windows OS. The software is programmed in Visual Studio. This software is interfaced with a data acquisition system and performs signal processing on the stream of acquired data.
I know that SDAccel is not compatible with Windows and therefore, I cannot use the software.
Please recommend the best tool (in Windows) where I can partition the software into programmable logic and processing system and perform hardware acceleration using the KCU 1500 board. I want to have the run time and development environment of the tool in Windows!
Thank you.
Re: hardware acceleration using KCU 1500
Hello @vivek,
Unfortunately there is no support or development for KCU1500 on windows OS.
I will recommend you to use a standalone linux machine for further development.
You can follow
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_3/ug1238-sdx-rnil.pdf
for more help.
Thank you.
Hi @kvasantr,
Thank you for the response.
Could you please recommend a xilinx board which is compatible with Windows OS?
Thank you.
Hello @vivek,
For the purpose you are looking for this is the only high performance board available with the latest Xilinx device.
This KCU1500 acceleration kit is the only one with the key features and benefits.
https://www.xilinx.com/products/boards-and-kits/dk-u1-kcu1500-g.html
Thank you.
