how to select the BITSTREAM.CONFIG.CONFIGRATE value?
[Netlist 29-154] Cannot set property 'BITSTREAM.CONFIG.CONFIGRATE' because incorrect value '33' specified. Expecting type 'enum' with possible values of '2.7,5.3,8.0,10.6,21.3,31.9,36.4,51.0,56.7,63.8,72.9,85.0,102.0,127.5,170.0'. ["E:/temp/arm/iphone8/Xapp_QUAD_SPI/project_1/project_1.srcs/constrs_1/imports/source/kcu105.xdc":45]
Re: how to select the BITSTREAM.CONFIG.CONFIGRATE value?
are you using ultrascale+ devices then you need to choose among the configrate  2.7, 5.3, 8.0, 10.6, 21.3, 31.9, 36.4, 51.0, 56.7, 63.8, 72.9, 85.0, 102.0, 127.5, 170.0
check page 310 in ug908 for the configrate.
This is the reason you see the message with the expeted values which I have copied here
