problem while trying leds access example
I am trying to do the example to access LEDs in the PL part of zedboard following the document
https://www.avnet.com/opasdata/d120001/medias/docus/3/SILICA_Xilinx_Zynq_ZedBoard_Vivado_Workshop_ver1.0.pdf
and im able to generate the bitstream file succesfully and when i export it to sdk and i build a example c code, there were no errors but when i run, it does not give me output. can anyone suggest me where i'm going wrong?
Re: problem while trying leds access example
Hello @sahithigurram25
Out of multiple example givens in the link which exact example are you trying to run ?
Can you check cross check jumpers power, power supply and switch settings and if there is any GPIO used switch used in the design to reset the LEDs ?
Thank you
It got solved. I forgot to specify the ios standards for the pins in constraints file. Thanks for the reply.
