Observer josecm
vcu1525 status leds
Hello, I've been trying to use the status leds (DS3) visible through a cut-out in the PCIe end bracket IN A VCU1525 to get some feedback. However, I've not had any success. I've believed the design is being correctly programmed in the device as the driver recognizes de PCIe device with the configured device and vendor ids. In desperation I've tried to apply a constant high value to the pins related to these leds (BA20, BB21, BC21) to see if the leds will be always on or off (depending if they're active low or high), but the yellow leds is constant, the green one is blinking and the red one is turned off. Below I show the block design an io assignment for this test. What I'm doing wrong? I'm I even able to control these leds?
Thank you in advance
Re: vcu1525 status leds
Hello @josecm,
Yes, you can use these LEDs for status indication.
Can you please share how you have applied constraints for these LEDs ?
they should be something like above. you can refer master constraint file given under user guide.
Thank you.
Observer josecm
@kvasantr thank you for your answer- Above I already show the I/O ports tab which I believe has these constraints. Nevertheless, below I show a screenshot of the xdc file with the led constraints.
Visitor mzofchak
I observe the same behavior as josecm when trying to write to the Status LED's (DS3).
I get a blink on Green and Red is always off.  I have not yet tried to drive the yellow LED.
Observer abilashjoseph
I also observe the same behavior. We are not able to access the Red, Green and Yellow LED's from the FPGA.
How should we control these LED's from FPGA?
Visitor yuriom
Does anybody figure this out yet? It has been quite some time...
Observer jribeiro_mog
it seems we are only able to manage the state of the yellow led from the FPGA. We implemented multiple designs by now where we successfully used it to debug and status information. We are also unable to get the green and red leds to the state we want from the FPGA.
Additionally, it is worth mentioning that we ran the system controller on the board and we were able to get the green and red leds to blink.
Best Regards,
Jose
Visitor yuriom
Ah, that clarifies things so much. Thank you!
