Participant gsanson
zc702 building video uses 2013.1 and I'm using 2014.4 Vivado
I was following along the video "Build a... the ZC702 evaluation kit" and when it came to Export the hardware there was no option under 2014.4 to open in SDK. How do I Export from 2014.4 and import into SDK?
This is all so confusing... :(
Re: zc702 building video uses 2013.1 and I'm using 2014.4 Vivado
Make sure your block diagram is open and then try as show in the figure below. Export-> Export Hardware.
Then make sure you tick 'Launch SDK' in the new pop up window.
Anirudh
