zcu102: restoring flash with SDK's GUI
I am trying to run BIT.exe (part of SCUI GUI) package to upgrade the firmware. I have repeatedly tried to upgraded and I keep getting the following error. The firmware version on the board - @ver command shows: May 17 2017 12;51:57.
Info: SYS_CTLR v1.30 RESTORE test started...
Info: The test will take 0 hours, 01 minutes, and 23 seconds. 0:01:23
Info: This step started at: 2018-09-18 16:22:25
User has confirmed: "Turn ZCU102 Board Power Off.
Set mode switch SW6 to "0" (Up,Up,Up,Up)
Connect two jumpers across J164 as shown in XTP433
Turn ZCU102 Power On"
step finished
Info: This step started at: 2018-09-18 16:22:28
after 2000
catch { disconnect }
1
after 2000
connect -url tcp:127.0.0.1:3121
attempting to launch hw_server
****** Xilinx hw_server v2017.2
**** Build date : Jun 15 2017-18:53:26
** Copyright 1986-2017 Xilinx, Inc. All Rights Reserved.
INFO: hw_server application started
INFO: Use Ctrl-C to exit hw_server application
INFO: To connect to this hw_server instance use url: TCP:127.0.0.1:3121
tcfchan#0
targets -set -filter {name =~"*APU*"}
rst -srst
after 3000
fpga -no-revision-check -file C:/ConsultingProjectsX/occupoint/zcu102_scui/flash_restore/tests/ZCU102/bitstream/boot_strap_loader.bit
initializing
0% 0MB 0.0MB/s ??:?? ETA
3% 0MB 1.8MB/s ??:?? ETA
7% 1MB 1.7MB/s ??:?? ETA
10% 2MB 1.7MB/s ??:?? ETA
12% 3MB 1.6MB/s ??:?? ETA
16% 4MB 1.6MB/s ??:?? ETA
19% 4MB 1.6MB/s 00:13 ETA
22% 5MB 1.6MB/s 00:12 ETA
25% 6MB 1.5MB/s 00:12 ETA
28% 7MB 1.5MB/s 00:11 ETA
32% 8MB 1.5MB/s 00:11 ETA
34% 8MB 1.5MB/s 00:10 ETA
38% 9MB 1.5MB/s 00:10 ETA
41% 10MB 1.5MB/s 00:09 ETA
44% 11MB 1.5MB/s 00:09 ETA
47% 11MB 1.5MB/s 00:08 ETA
50% 12MB 1.5MB/s 00:08 ETA
53% 13MB 1.5MB/s 00:07 ETA
56% 14MB 1.5MB/s 00:07 ETA
59% 15MB 1.5MB/s 00:06 ETA
62% 15MB 1.5MB/s 00:06 ETA
65% 16MB 1.5MB/s 00:05 ETA
68% 17MB 1.5MB/s 00:05 ETA
71% 18MB 1.5MB/s 00:04 ETA
74% 18MB 1.5MB/s 00:04 ETA
77% 19MB 1.5MB/s 00:03 ETA
80% 20MB 1.5MB/s 00:03 ETA
83% 21MB 1.5MB/s 00:02 ETA
86% 21MB 1.5MB/s 00:02 ETA
89% 22MB 1.5MB/s 00:01 ETA
93% 23MB 1.5MB/s 00:01 ETA
95% 24MB 1.5MB/s 00:00 ETA
98% 25MB 1.5MB/s 00:00 ETA
100% 25MB 1.5MB/s 00:16
source C:/ConsultingProjectsX/occupoint/zcu102_scui/flash_restore/tests/ZCU102/tcl/bsl_psu_init.tcl
psu_init
after 1000
psu_ps_pl_isolation_removal
after 1000
psu_ps_pl_reset_config
targets -set -filter {name =~"*A53*0"}
rst -processor
dow C:/ConsultingProjectsX/occupoint/zcu102_scui/flash_restore/tests/ZCU102/elf/boot_strap_loader.elf
Downloading Program -- C:/ConsultingProjectsX/occupoint/zcu102_scui/flash_restore/tests/ZCU102/elf/boot_strap_loader.elf
section, .text: 0x00000000 - 0x0001442f
section, .init: 0x00014440 - 0x00014473
section, .fini: 0x00014480 - 0x000144b3
section, .note.gnu.build-id: 0x000144b4 - 0x000144d7
section, .rodata: 0x000144d8 - 0x00014dcf
section, .rodata1: 0x00014dd0 - 0x00014dff
section, .sdata2: 0x00014e00 - 0x00014dff
section, .sbss2: 0x00014e00 - 0x00014dff
section, .data: 0x00014e00 - 0x00015fe7
section, .data1: 0x00015fe8 - 0x00015fff
section, .ctors: 0x00016000 - 0x00015fff
section, .dtors: 0x00016000 - 0x00015fff
section, .eh_frame: 0x00016000 - 0x00016003
section, .mmu_tbl0: 0x00017000 - 0x0001700f
section, .mmu_tbl1: 0x00018000 - 0x00019fff
section, .mmu_tbl2: 0x0001a000 - 0x0001dfff
section, .preinit_array: 0x0001e000 - 0x0001dfff
section, .init_array: 0x0001e000 - 0x0001e007
section, .fini_array: 0x0001e008 - 0x0001e047
Info: This step started at: 2018-09-18 16:23:17
File sent successfully
Error: BSL Flashing Failed
Error: Found regular expression in step 3 of test 1 - "(.*)Error(.*)"
Info: This step started at: 2018-09-18 16:23:49
Error: Stopped because step 3 failed in test 1
step finished
Error: Could not find regular expression in step 0 of test 1 - "(.*)MSP v1.10 I2C Bridge v1.30(.*)"
Info: Result for step 0: Fail
Info: Result for step 1: Pass
Info: Result for step 2: Pass
Info: Result for step 3: Fail
Info: The test took 0 hours, 01 minutes, and 23 seconds. 0:01:23
Re: zcu102: restoring flash with SDK's GUI
Hi @rogermathworks
Go through AR#69640. Check driver version is 6.7 or not.
If not, follow procedure provided below:
Check you are using ES version of silicon or production version of silicon.
To do this, open the Vivado Hardware Manager and check the Hardware Device Properties.
If first digit in the IDCODE is 2 or greater, this is production ZU9EG silicon and you should use the -C System Controller files.
If first digit in the IDCODE is 1, then you should use the -ES2 System Controller files.
Download SCUI according your board silicon at https://www.xilinx.com/support/documentation-navigation/see-all-versions.html?xlnxproducttypes=Boards%20and%20Kits&xlnxdocumentid=XTP433
As you are using hw_server v2017.2 and if your board having ES2 silicon then use
For production silicon following files should work
Bhushan
Bhushan
Thank you very much for your response Bhushan.
1. I am running on Windows 7
2. I find that the device driver is 6.7.0
3. I have production silicon - ID CODE  24738093
4. I used the version 9 tutorial and software
5. I get to the point of flashing complete remove jumper and power off/on.
6. Step 0 after that fails as shown below.
Board: ZCU102
Serial Number: 881419981751-78002
Mac Address: 00:0A:35:04:9F:49
Info: SYS_CTLR v1.50 RESTORE test started...
Info: This step started at: 2018-09-21 11:51:58
step finished
Info: This step started at: 2018-09-21 11:52:06
after 2000
1
after 2000
tcfchan#0
rst -srst
after 3000
initializing
3% 1MB 2.0MB/s ??:?? ETA
6% 1MB 1.7MB/s ??:?? ETA
15% 4MB 1.6MB/s ??:?? ETA
18% 4MB 1.6MB/s 00:13 ETA
22% 5MB 1.5MB/s 00:12 ETA
30% 7MB 1.5MB/s 00:11 ETA
37% 9MB 1.5MB/s 00:10 ETA
40% 10MB 1.5MB/s 00:09 ETA
43% 11MB 1.5MB/s 00:09 ETA
46% 11MB 1.5MB/s 00:09 ETA
49% 12MB 1.5MB/s 00:08 ETA
52% 13MB 1.5MB/s 00:08 ETA
55% 14MB 1.5MB/s 00:07 ETA
58% 14MB 1.5MB/s 00:06 ETA
61% 15MB 1.5MB/s 00:06 ETA
64% 16MB 1.5MB/s 00:05 ETA
67% 17MB 1.5MB/s 00:05 ETA
69% 17MB 1.5MB/s 00:05 ETA
73% 18MB 1.5MB/s 00:04 ETA
76% 19MB 1.5MB/s 00:04 ETA
79% 20MB 1.5MB/s 00:03 ETA
82% 20MB 1.5MB/s 00:02 ETA
85% 21MB 1.5MB/s 00:02 ETA
88% 22MB 1.5MB/s 00:01 ETA
91% 23MB 1.5MB/s 00:01 ETA
94% 23MB 1.5MB/s 00:00 ETA
97% 24MB 1.5MB/s 00:00 ETA
psu_init
after 1000
after 1000
rst -processor
Info: This step started at: 2018-09-21 11:52:37
Info: This step started at: 2018-09-21 11:53:09
!! Press ESC to enter System Controller mode.
User has confirmed: "Remove the jumpers and cycle ZCU102 Board Power."
step finished
Info: This step started at: 2018-09-21 11:53:34
****** Vivado v2017.2 (64-bit)
**** SW Build 1909853 on Thu Jun 15 18:39:09 MDT 2017
**** IP Build 1909766 on Thu Jun 15 19:58:00 MDT 2017
source {tcl\five_second_delay.tcl}
# after 5000
INFO: [Common 17-206] Exiting Vivado at Fri Sep 21 11:53:46 2018...
step finished
Info: This step started at: 2018-09-21 11:53:47
Writing: '\x1b'
Writing: '\x08'
[('', 'VRN', '', '')]
Writing: '\t'
:R
Writing: 'VRN\r\t'
'\r\n!! Press ESC to enter System Controller mode.\r\n\x08:R\r'VRN
:P
step finished
Error: Could not find regular expression in step 0 of test 0 - "(.*)MSP v1.50 I2C Bridge v1.50(.*)"
Info: Result for step 3: Pass
Info: Result for step 4: Pass
Info: Result for step 5: Pass
Info: Result for step 6: Fail
Please see my last post. With the suggestions from Bhushan, I was able to make some progress, but I continue to get failure, after I remove the jumper for J164 and re-power (as shown in my previous post). Do you have any suggestions?
Can you check the Interface number (here we have interface 0) reported by device manager. If it is different then modify the interface number and update the .bat file.
firmware_flash_gui_070517.bat which can be found in flash_restore>tests>zcu102>bat. & rerun the same steps.
cd bat
MSP_BSL_Flasher.exe -f "..\elf\MSP_code_070517.txt" -c "Silicon Labs Quad CP210x USB to UART Bridge: Interface 0" -v -p
Harshit
Newbie mnt
Hi, I have the same problem as roger mentioned above. I have reached till the point where it asks me to remove jumpers and restart the board. But it fails at step 0 and 6.
I did check for my interface it is 0. Can you please suggest any other trouble shooting techniques?
Thank you!
Newbie mnt
Any luck with this roger?
