Participant lacirta
7 series fpga ace player compatibility
Hi all!
So far we were using the embedded JTAG ACE player (xapp424) for reflashing our Virtex-5 FPGA boards.
We would like to use the same method for BPI-flashing in a Kintex-7 FPGA.
It is said there, that it can be implemented in any device:
https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Embedded-JTAG-ACE-Player-Spartan-6/td-p/62697
Is this still supported for this FPGA family, or we have to use something like XAPP518 instead?
L.
Re: 7 series fpga ace player compatibility
could you provide a block diagram how you planned to use BPI flash with 7-series fpga in your system?
if you are looking to use BPI flash programming with newer revisions then you can also check the following application note
https://www.xilinx.com/support/documentation/application_notes/xapp1282-us-post-cnfg-nor-axi-emp-ip.pdf
