A question about "write_cfgmem"
I have two files and want to emberge them toghether to be on *.mcs file for configuring the flash (size : 32MB).
Here is the command I used:
write_cfgmem -format mcs -interface SPIx4 -size 32 -loadbit "up 0x0 alisha_xilinx.bit" -loaddata "up $::env(BITSIZE) bbl" -file $mcsfile -force
Addr1                   Addr2                              Date File(s)
0x00000000 0x0050554F Sep 23 19:08:09 2019 work-fpga/alisha_xilinx.bit
0x00600000 0x013DE27F Sep 26 11:30:30 2019 work-fpga/bbl
0 -rw-r--r-- 1 root root 54471800 Sep 26 11:30 alisha_xilinx.mcs
The total size of bbl + bit is around 20MB (x013DE27F) why the final size of mcs is around 54MB?
Re: A question about "write_cfgmem"
The MCS is a encoded file type, it is not literally the bit for bit representation of what is in the flash.
If you could look at the content at the bit level of the MCS, with a hex viewer for example, it would NOT be the same as the bit level content of the flash.
Look at the Wikipedia article I referenced.
Because it is an MCS file and not a raw binary.
MCS is ASCII (text) encoded so the data is at least doubled.  It also has some address and command bytes.  Look at the wikipedia article on the Intel HEX format.
@necare81
Thanks a lot!
That makes sense.
One wired thing is the  capacity of QSPI flash on my FPGA board is just 32MB. While even I program this 54MB MCS file to the flash the vivado hardware manager complains nothing and told me the programming is successful.
There is no checking the size of the file and the capacity of the flash?
Or it just checks the *.bit file used for the FPGA configuration and not for others (bbl in my case used for linux booting)
Is this a bug?
You can refer to these two ARs. Overhead in the mcs doesn't occupy the memory space.
https://www.xilinx.com/support/answers/43961.html
https://www.xilinx.com/support/answers/476.html
Harshit
Got it!
Thanks!
