Visitor thdoerfler
ARTIX-7: Reprogramming via hardware manager/jtag need power cycle
I am currently developing on a artix-7 (xc7a15t) device and have one annoing issue: device programming vie hardware manager/jtag works fine, when the device is blank. But when I loaded the device once via the JTAG interface, a second attempt to program it (with a different program) fails silently.
- When I start the "Program Device..." procedure interactively, the "Program Device" bitstream file selection box pops up.
- After pressing the "Program" button, the progress indicator stays a 1% for about 1 second
- then it refreshes the debug(XADC/ILA...) module lists and finishes
- but the program is still the previous one.
Any ideas what I might make wrong?
My configuration:
- openSuSE 15.0 64 bit (yes, it's not supported ;-) )
- vivado 2019.1
- Digilent HS2 debug interface
Visitor thdoerfler
Re: ARTIX-7: Reprogramming via hardware manager/jtag need power cycle
Finally I had time to track down the fault:
We had a reset generator connected to the PROG_B pin and mysteriously this caused the JTAG reprogramming to fail.
No idea why this happens, but anyway I doubt that the reset generator at this pin was a good idea...
Teacher drjohnsmith
can you post a picture of your HS2 please,
there are a number of pirate copies, that I have noticed do not support linux.
apart from that, I assume its your own board,
can you monitor the program and done pins,
Visitor thdoerfler
Hi drjohnsmith,
I assume the digilent HS2 is properly supported because the initial programming and also the interfacing to implemented ILAs works like a charm. Anyway I append a picture of the HS2 unit.
Teacher drjohnsmith
that's a good one,
get the scope out on the done and progb lines,
Visitor thdoerfler
