Nizlas
AXI Quad SPI Active High Slave Select
I am using AXI Quad SPI IP to communicate with HMC701 and HMC704. Unfortunately both of them have a active-high slave select.
Is it possible to change the polarity of the slave select signal in the IP or do I have to add an inverter?
Best regards
