All pins HIGH in SPARTAN 6
Hi!
I program (ISP) the flash memory via Spartan 6 by USB Platform Cable II. But I have some peripheral devices that are directly connected to the FPGA. And when I program the flash memory by USB Platform Cable II the FPGA set pins N5 and P4 (IO_L49P_D3_2 and IO_L63N_2) in HIGH. Somebody know how remove this behavior when I in-system program that flash via FPGA?
Thanks!
You might be on to a looser here,
As far as I remember, the choice is to have IO pulled up internally or to have them float during configuration.
This is set by an external pin,
Floating the outputs with out a pull up / down resistor externally, you don't know which level your going to have, so it may work today ,and not tomorrow.
Sorry, Sounds like its a mod / re spin.
I think it's very useful remark. Do not forget to install weak pull-up/down resistors where it's necessary.
