Observer mbianconi
Answer record 38077 missing
I'm just having an issue with failed multiboot configuration on a Spartan-6 device when a specific corrupted bin image file is loaded as user image.
I've found some help in AR 58249 (http://www.xilinx.com/support/answers/58249.html), however the link to 38077, describing the bad packet error seems to lead nowhere.
Re: Answer record 38077 missing
Hi @mbianconi
Check this link.
http://china.xilinx.com/support/answers/38077.html
Thanks,Vijay
Hi @mbianconi
Check this link.
Thanks,Vijay
Visitor vanastasiou
The link you provided is also not working. It returns with a 404 error Page Not Found. Could you please provide us with a valid link to that AR because we're having a major issue with programming failure of an Artix7 device due to BAD PACKET ERROR?
