Artix-7 ICAPE2 and STARTUPE2
I'm trying to work with the multiboot capabilities of the ARTIX-7 through the ICAPE2 interface.  Eventually, I'd like to be able to program a second image in the flash (in addition to a fallback already programmed) and configure from it via the warm start.  This means that I need access to the CCLK pin (to read/write/program the SPI flash), available through STARTUPE2, as well as the ICAPE2 primitive.
To date, while my design builds, none of the interaction with the ICAPE2 primitive seems to do anything.  My logic looks like: (before bit swapping within each byte of I)
CS=1, RDWRB=0, I=32'hffffffff // Dummy word, transitioning to RDWRB=0
CS=0, RDWRB=0, I=32'hffffffff // Dummy word, first word written to interface
CS=0, RDWRB=0, I=32'h000000bb // Bus width detection, 32 bit bus (X32)
CS=0, RDWRB=0, I=32'h11220044
CS=0, RDWRB=0, I=32'hffffffff // Another dummy word
CS=0, RDWRB=0, I=32'haa995566
CS=0, RDWRB=0, I=32'h20000000
CS=0, RDWRB=0, I=32'h2800e001 // Read status register (as an example)
CS=0, RDWRB=0, I=32'h20000000 // NOOP
CS=1, RDWRB=0, I=32'h20000000 // Interface deactivated
CS=1, RDWRB=1, I=32'h20000000 // Change RDWRB to read mode
CS=0, RDWRB=1, I=32'h20000000 // Wait one cycle
CS=0, RDWRB=1, I=32'h20000000 // Wait a second cycle
CS=0, RDWRB=1, I=32'h20000000 // Third wait cycle--should see answer now
CS=1, RDWRB=1, I=32'h20000000 // Deactivate interface
CS=1, RDWRB=0, I=32'h20000000 // Change RDWRB to write mode
CS=0, RDWRB=0, I=32'h30008001 // Issue a command
CS=0, RDWRB=0, I=32'h0000000d // DESYNC command
CS=1, RDWRB=0, I=32'h20000000 // Deactivate interface
At this point, I'm at a loss regarding what I am doing wrong.  Nothing I do changes the ICAPE2 output--it's a constant 32'ffffffdb.  Waiting extra cycles doesn't change it (up to 5), adding extra NOOPs after the read command doesn't change it.  Nothing I do changes this value.
So, I'll ask, is it possible that I'm struggling because I have the STARTUPE2 primitive running as well in order to control the SPI flash on my board?  Does the CCLK (i.e. SPI flash clock) need to be active for any of this to work?  Or am I missing something somewhere else?
Thanks!
You simply need to get the bitstream, swapping and control right. I currently don't have the bandwidth to check, but, for example, you issue the bus width detection in your code. It shouldn't matter, but that is only for parallel (8/16/32) config.
This link is the one that has me concerned.  It suggests that ICAPE2 and STARTUPE2 cannot be used in the same design, but the context is just simulation and not synthesis.  Is it true that these cannot be used in the same design during synthesis as well?  Are there limitations associated with using them in the same design?
Of course you can use both of those in the same design. The other forum discussion only relates to the simulation of the GSR function (which you probably shouldn't be using in the first place). For synthesis these are simply instantiations and in hardware they are independant, seperate blocks whith no co-dependencies.
Well, thanks for the quick reply, but that leaves me as stuck as before.
I'm attaching my ICAPE2 interaction module.  If you have the opportunity, I'd appreciate it if you could take a peek at it and tell me if you see any errors.
It sounds like you want to eventually warm boot via ICAP. Then take a look at the attached. Sorry, it's in VHDL.
Ops. Here you go
-- 7-Series reset/reconfiguration via ICAPE2.
library work;
library IEEE;
use IEEE.std_logic_1164.all;
library UNISIM;
use UNISIM.vcomponents.all;
entity iprog_rst is
  generic (
    WBSTAR  : std_logic_vector(31 downto 0) := x"00000000"     -- insert your warm boot address here
  port (
    RST     : in  std_logic;
    CLK     : in  std_logic;
    RIP     : out std_logic
end iprog_rst;
architecture arch_iprog_rst of iprog_rst is
   constant  CMAX    : integer := 32;
   signal  count     : integer range 0 to CMAX := 0;
   signal  run       : std_logic := '0';
   signal  cs_l      : std_logic := '1';
   signal  r_wx      : std_logic := '1';
   signal  data      : std_logic_vector(31 downto 0);
   signal  d_swapped : std_logic_vector(31 downto 0);
begin
process(CLK)
begin
   if(CLK'event and CLK='1') then
      if(RST = '1')  then
         run      <= '1';
      end if;
      if(run = '0')  then
         RIP      <= '0';
         cs_l     <= '1';
         r_wx     <= '1';
         count    <= 0;
         data     <= (others => '1');
      else
         RIP      <= '1';
         if(count /= CMAX)  then
            count <= count + 1;
         end if;
         case count is
            when  0 => data <= x"FFFFFFFF";   -- Dummy Word
            when  1 => data <= x"FFFFFFFF";   -- Dummy Word
            when  2 => data <= x"FFFFFFFF";   -- Dummy Word
            when  3 => data <= x"FFFFFFFF";   -- Dummy Word
            when  4 => data <= x"FFFFFFFF";   -- Dummy Word
            when  5 => data <= x"20000000";   -- Type 1 NO OP
               cs_l  <= '0';
               r_wx  <= '0';
            when  6 => data <= x"AA995566";   -- Sync Word
            when  7 => data <= x"20000000";   -- Type 1 NO OP
            when  8 => data <= x"20000000";   -- Type 1 NO OP
            when  9 => data <= x"30020001";   -- Type 1 Write 1 Word to WBSTAR
            when 10 => data <= WBSTAR;        -- Warm Boot Start Address
            when 11 => data <= x"20000000";   -- Type 1 NO OP
            when 12 => data <= x"20000000";   -- Type 1 NO OP
            when 13 => data <= x"30008001";   -- Type 1 Write 1 Words to CMD
            when 14 => data <= x"0000000F";   -- IPROG Command
            when 15 => data <= x"20000000";   -- Type 1 NO OP
            when 16 => data <= x"20000000";   -- Type 1 NO OP
               cs_l     <= '1';
               r_wx     <= '1';
            when others =>
               cs_l     <= '1';
               r_wx     <= '1';
         end case;
      end if;
   end if;
end process;
d_swapped(31)     <= data(24);
d_swapped(30)     <= data(25);
d_swapped(29)     <= data(26);
d_swapped(28)     <= data(27);
d_swapped(27)     <= data(28);
d_swapped(26)     <= data(29);
d_swapped(25)     <= data(30);
d_swapped(24)     <= data(31);
d_swapped(23)     <= data(16);
d_swapped(22)     <= data(17);
d_swapped(21)     <= data(18);
d_swapped(20)     <= data(19);
d_swapped(19)     <= data(20);
d_swapped(18)     <= data(21);
d_swapped(17)     <= data(22);
d_swapped(16)     <= data(23);
d_swapped(15)     <= data(8);
d_swapped(14)     <= data(9);
d_swapped(13)     <= data(10);
d_swapped(12)     <= data(11);
d_swapped(11)     <= data(12);
d_swapped(10)     <= data(13);
d_swapped(9)      <= data(14);
d_swapped(8)      <= data(15);
d_swapped(7)      <= data(0);
d_swapped(6)      <= data(1);
d_swapped(5)      <= data(2);
d_swapped(4)      <= data(3);
d_swapped(3)      <= data(4);
d_swapped(2)      <= data(5);
d_swapped(1)      <= data(6);
d_swapped(0)      <= data(7);
ICAPE2_inst: ICAPE2
generic map (
   ICAP_WIDTH => "X32"  -- Specifies the input and output data width.
port map (
   O     => open,       -- 32-bit output: Configuration data output bus
   CLK   => CLK,        -- 1-bit input: Clock Input
   CSIB  => cs_l,       -- 1-bit input: Active-Low ICAP Enable
   I     => d_swapped,  -- 32-bit input: Configuration data input bus
   RDWRB => r_wx        -- 1-bit input: Read/Write Select input
end arch_iprog_rst;
Sure, I'll try that, ... but I was hoping to be able to read from the port in addition to writing to it.  You know, something to give me an assurance that the various commands I was issuing actually worked before I jumped all the way to a warm boot.  It's the reading, before I got to the writing, that I was having problems with. (Writing wasn't working yet either, but it was next on my list.)
Many thanks for the help!  Much to my surprise, the code you posted was the final straw in what I needed to figure out what was going on.  I now have working verilog code that works with this interface.  While it may not be perfect, or as tight as it could be, it does work.
Further, for the sake of your readers and others who may be struggling with the same thing, I'm attaching my working verilog code to this message.  (Why?  Because of everyone else who attaches their broken verilog code, whose code I read while trying to get this thing to work ...)
Thank you again!
dgisselq,
Thanks for posting your Verilog Wishbone code.  I like your approach, but I needed it in VHDL.  I translated it, simplified the Wishbone pieces a little so it would fit into my Wishbone system and it ran exactly as you described.  Thanks again for the post.  Attached are my modifications.
@ralfk Based on the design you provided, can this procedure also be used to download a partial bitstream from SPI Flash memory? I tried something but it didn't work.
abdullah
For me it does not work, do nothing.. :(
I have tried clk as 100Mhz, and than slower via a counter. No results.
What should be clk? 1Khz? 1Mhz? 100Mhz? A have not found any information about it.
What sould I do to solve it?
sassi
