zstibi
Artix-7 and JTAG programmers compatibility
Is Platform Cable (not II, but DS300) compatible with Artix7 FPGA family and Vivado IDE?
If not, then which programmer device should I use?
Tibor
@zstibi
Welcome to the Xilinx Forum!
Xilinx document UG908 (page 24) shows the programmers supported by the Vivado IDE v2019.1, which are:
• Xilinx® SmartLynq Data Cable (HW-SMARTLYNQ-G/DLC20)
• Xilinx Platform Cable USB II (DLC10)
• Xilinx Platform Cable USB (DLC9G, DLC9LP, DLC9)
• Digilent JTAG-HS1
• Digilent JTAG-HS2
• Digilent JTAG-HS3
• Digilent JTAG-SMT1
• Digilent JTAG-SMT2
These programmers can be used to program the Artix-7 FPGA.
Cheers,
Mark
@zstibi
• Digilent JTAG-HS1
• Digilent JTAG-HS2
• Digilent JTAG-HS3
Cheers,
Mark
zstibi
Thank you for the satisfactory answer!
