Artix 7 master SPI question
I am wondering if the INIT_B pins of Artix 7 could be controlled as in Master BPI configuration mode to delay the FPGA configuration.
Re: Artix 7 master SPI question
UG470 under Power-on Sequence Precautions  in the Master SPI Configuration Mode explicetely states:
"Hold the FPGA_INIT_B pin Low from power-up to delay the start of the FPGA configuration procedure. Release..."
Yes you can delay configuration after power up by holding INIT_B low.
Anirudh
Great.
Many thanks for your generous help.
