Artix-7 support for Spansion S25FS
Does the Artix-7 support Spansion S25FS series flash devices? Specifically I am looking at a S25FS256SAGMFI000.
Nicholas
Tags (3)
Re: Artix-7 support for Spansion S25FS
Hello @nicholas_schmidtke,
The flashes listed in Table C-1 in Appendix C from below UG are supported with Artix 7 devices
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2015_3/ug908-vivado-programming-debugging.pdf
Ashish
Scholar pratham
@nicholas_schmidtke i dont see flash listed under artix 7. Use supported flash
-Pratham
In iMPACT 14.7 - 7-series  FPGA supports S25FL256S flash, That was mentioned in the following Xilinx published AR http://www.xilinx.com/support/answers/59213.html
