Anonymous
Not applicable
Ask the configuration voltage and configuration current
hey everyone:
     I want to see the configuration voltage and configuration current  when measure power by use Xilinx Power Estimator(XPE). I want to check the configuration voltage and configuration current information  in Power supply panel. Such the figure view, the configuration voltage is Vcco_1.5V, the configuration current is 0.319A. right?
thanks
Kuan_Wen
If all XPE entries are correct (Including environment entries)as per your design then the supply currents summary by selecting maximum process gives  configuration current -- provided if you followed power-up sequences as per data sheet
