BITSTREAM.CONFIG.PERSIST for Partial Reconfiguration Using External Configuration Modes (other than JTAG)
Page 119 of Partial Reconfiguration, UG909 (v2018.3) December 5, 2018 says:
To use external configuration modes (other than JTAG) for loading a partial BIT file, these pins must be reserved for use after the initial device configuration. This is achieved by using the BITSTREAM.CONFIG.PERSIST property to keep the dual-purpose I/O for configuration usage and to set the configuration width. Refer to this link in the Vivado Design Suite User Guide: Programming and Debugging (UG908) [Ref 25]. The Tcl command syntax to set this property is:
set_property BITSTREAM.CONFIG.PERSIST <value> [current_design]
where <value> is either No or Yes.
When should I set this property, before implementation or before bitstream generation? How do I know if it is set to Yes or No? Thanks.
Hi @wanqingxilinx,
This property should be set before bitstream generation. You can also add this tcl in XDC. You can check the property by the command in AR#54073:
https://www.xilinx.com/support/answers/54073.html
Simon
Hi @wanqingxilinx,
Simon
Thanks simon for the answer. I think that answered my questions, although my partial reconfiguration still does not work after doing
Re:
set_property BITSTREAM.CONFIG.PERSIST Yes [current_design]
set_property CONFIG_MODE {S_SELECTMAP} [current_design]
report_property -all  [current_design] BITSTREAM*
Property                                  Type    Read-only  Value
BITSTREAM.CONFIG.PERSIST                  enum    false      Yes
report_property -all  [current_design] CONFIG_MODE
CONFIG_MODE  enum  false      S_SELECTMAP
Hello, we are doing some reconfigurable design around ICAP. According to the instructions in the document, do I need to disable persist in order for ICAP to work normally?
At present, we tried the Microblaze+HWICAP IP core, and then directly applied the selftest case in the SDK. But every time I read back the IDCODE, I always read FFFFFFD9, which we are very confused about
