smegeed
Bitstream readback security
I was wondering what the difference between
BITSTREAM.READBACK.SECURITY  set to Level 2 (no read back and no reconfigurations) vs
BITSTREAM.GENERAL.DISABLE_JTAG
Secondly does the readback security setting allow the use of JTAG debugging (ila etc. in the hardware manager)
ddn
@smegeed ,
Yes, readback security setting allow the use of JTAG debugging (ila etc. in the hardware manager). This is the difference.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
@smegeed ,
Deepak D N
barriet
Note that this is not a strong security feature without authentication. For more details, see https://www.xilinx.com/support/documentation/application_notes/xapp1098-tamper-resist-designs.pdf
Cheers,
bt
