jiongsi
Booting device from configuration memory failed
After programmed flash memory with a .mcf file, then boot from the flash memory, but failed. No other error information. Any ideas what's wrong? Thanks.
jiongsi
Thank you for your reply.
Earlier the FPGA_M[2:0] was set as "111" by mistake, the boot from flash memory works after set it as "001".
iguo
You should always tell what FPGA and flash you are using for a configuration question; and then, read the status register after the failure.
jiongsi
