rg.jones
CPLD programmin on Windows 10
Hello, I am looking for some guidance on programming XC9500XL series CPLDs. I have used older versions of ISE on Windows 7 but I am now on Windows 10 and I am having trouble trying to find a compatible version of ISE (or later software) that will install on Windows 10 and still let me use my DLC09 USB based JTAG programmer to update the CPLD.
Would appreciate any suggestions.
Glenn
iguo
ISE is not supported on Win10. You will need to stick to Win7 with another PC.
You can also consider slave programming by a microprocessor; or some off-line programmer.
wduffy
Hi @rg.jones,
On February 20th there was a new 14.7 ISE Design Suite Download for Windows 10 placed on www.xilinx.com.
See the following link:
https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/vivado-design-tools/archive-ise.html
This release is intended to support all ISE devices.
Installation Guide and Release Notes: https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug1227-ise-vm-windows10.pdf
Known Issues: https://www.xilinx.com/support/answers/68433.html
Wendy
Xilinx Technical Support
rg.jones
Thank You - Wendy
rg.jones
I have tried everything I could think of but I am not able to use my DLC09 USB based JTAG programmer to update the CPLD or my Diligent parallel cable. Has anyone else sucessfully used programming CPLD devices under this Windows 10 image? If so what did you use?
bpatil
Hello @rg.jones
Please provides snapshots and logs of your issue.
Connect programming cable to Laptop/PC and check in windows driver you see Xilinx cable detected or not. Kindly capture snapshot and share.
Kindly check https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Quickly-install-Cable-Drivers-for-Xilinx-Platform-Cable-USB-II/ba-p/1013230
Bhushan
rg.jones
I am back at this again and now I am not even able to install the product. Which logs do you need @bpatil
bpatil
@ddn Can you please check on it?
Bhushan
