Visitor nemesis64
Can not get DLC9LP to work on any OS
So frustrating that I only need to use this DLC9LP for maybe 10 minuntes but
I've spent over 12 hours trying to get iMPACT to detect my device...
I can't seem to connect to my DLC9LP with iMPACT on either Linux or Windows OS's...
Typically resulting in either:
"iMPACT - Module windrvr6 is not loaded." or
WARNING:iMPACT - The cable selected is not avaliable, please select a different one.
I can't see why a USB bootable Linux OS including drivers, couldn't be provided....
Operating System (OS) support on Vivado Design Tools
https://www.xilinx.com/support/answers/54242.html
Operating System (OS) Support on Xilinx ISE Design Tools
https://www.xilinx.com/support/answers/18419.html
I dont even know how to proceed anymore, I've tried every avenue...
回复: Can not get DLC9LP to work on any OS
Have you followed the steps in Chapter 1, https://www.xilinx.com/support/documentation/user_guides/ug344.pdf to install the cable driver? The error you pasted here indicates the driver is not installed.
Make sure you unplug the cable while installing. Once finished, you re-plug the cable, and a installation success window would pop up 2~3 times and only after that the cable can start to work.
Visitor nemesis64
Yep, did all that....
Currently on my Win10 machine, tried ISE_DS and ISE_VM both unsuccessful even after installing drivers.
I've tried every solution I could find on your forums,
When I connect it to my laptop it makes the audio sound for connecting to a usb device, but I can't seem to be able to find it in device manager.
But on my Linux only system, using "lsusb" command I am able to find it, however Linux Mint is unsupported.
Is there a supported open source distro of Linux?
Visitor nemesis64
Yep tried all that...
I've tried every solution I could find on Xilinx forums all without success...
On my Win10 machine, when I plugin the device it makes the audio sound that it has been plugged in
but I can't seem to be able to find it in device manager like that I've seen in other posts...
However on my Linux only machine I was able to detect it using "lsusb" command,
unfortuntly my version of Linux is unsopprted and was unable to install drivers...
Is there a open source distro of Linux that is supported?
I guess there is no open source for Linux.
For Windows 10 OS, can you try Vivado? ISE is not supported on it and ISE_VM is only a very limited version for Spartan-6 only (though with this version, my USB cable does work..)
I suppose you tried the various re-installing cable drivers methods right? Test with the check_windrvr6.exe/install_drivers.exe in //cable_drivers/nt64/?
You cannot see it in device manager, with cable attached, if you scan changes in device manager, can it show a big yellow question mark in some of the item? If so, you can select 'update or re-install' drivers from Xilinx installation file path, this can work sometimes.
If needed follow the steps listed in here https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/Quickly-install-Cable-Drivers-for-Xilinx-Platform-Cable-USB-II/ba-p/1013230
Harshit
Visitor nemesis64
Quote "I suppose you tried the various re-installing cable drivers methods right?" Yes
I think it's pretty obviouse what the problem is now....
I got stuck with a clone from eBay even though they were advertising a genuine product.
They still are trying to stick with their claims but I have enough evidence that suggests otherwise.
https://forums.xilinx.com/t5/Design-Tools-Others/Using-3rd-Party-JTAG-Cables/td-p/362061
On the other hand I was able to install ISE including drivers using a method I found on youtube,
Can confirm (from what I can see without a wokring platform cable) working on current versions of Ubunutu and Linux Mint.
https://www.youtube.com/watch?v=meO-b6Ib17Y
The instructions could have been simplified or even put into a script but it seems to do the trick
Scholar watari
Hi @nemesis64
Would you share the picture of DLC9LP ?
Especially, I'd like to confirm surfece of it.
I suspect it's fake device or unauthrized device. not clone.
Best regards,
Visitor nemesis64
Well from what I can tell a clone should look a little something like this
https://www.eevblog.com/forum/fpga/xilinx-usb-platform-cable-clone/
But I got this (just a little bit missing...)
Scholar watari
Hi @nemesis64
Sorry for my late reply.
Unfortunately, it seems similar case as below.
https://forums.xilinx.com/t5/Configuration/Platform-cable-on-Ubuntu/td-p/996159
Best regards,
Visitor nemesis64
The supplier replaced it with another "clone"...
Actually is being detected now, but having issues with obtaining a VREF
