Can't uninstall ECM driver
I cannot uninstall the ECM driver.  When I follow the path that is shown in the popup error message box, the "uninstall" folder is not there.  How do I uninstall this from my PC?
Dan
Re: Can't uninstall ECM driver
Hello @edadangtri
Did you deleted Vivado 2017.4 setup folder from your Laptop/PC?
Most probably this could be be cause uninstalling ECM driver is not working for you.
Try utility provided at  https://support.microsoft.com/en-gb/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed
Bhushan
