Cannot program efuse
Following the steps in XAPP1267, I am trying to "right-click the UltraScale FPGA to allow selection of either Program BBR Key... or Program eFUSE Registers...". I am using the approved xilinx Platform Cable USB II cable. However, unlike figure 2 in XAPP1267, my hardware manager is not showing "program efuse registers...", as shown:
Any ideas why?
Re: Cannot program efuse
Hi @ryanjohnson8,
The XAPP you refer to is specific to UltraScale and UltraScale+ devices.
From the screenshot you shared it looks like you are using a Zynq UltraScale device. Programming of the eFUSEs of such devices would not be directly supported via Vivado.
The recommendation would be to use the XilSkey library.
Have you see XAPP1319?
https://www.xilinx.com/support/documentation/application_notes/xapp1319-zynq-usp-prog-nvm.pdf
Wendy
Xilinx Technical Support
Hi @ryanjohnson8,
Wendy
