Check crc when reading bitstream from prom using .mcs format
I uploaded the prom in mcs format.
When downloading bitstream from prom, does FPGA check crc for bitstream?
As @thakurr said, it does check for CRC error. Now there might be a case where it ignores the CRC check.
During configuration FPGA look for SYNC word to start the configuration. In case where synchronization was lost, any subsequent commands not understood including the command to check the CRC. i.e. extraneous SPI bus activity from possibly moving the FPGA configuration logic to an unexpected state. In this situation, configuration fails with DONE Low and INIT_B High because the CRC was ignored. You can check more on startup phase in UG470 page#90 https://www.xilinx.com/support/documentation/user_guides/ug470_7Series_Config.pdf
Hope it helps.
Harshit
Hi @wio000
Yes, it does check the CRC while you boot from the flash. You can check this in the Hw manager under device properties. The configuration status registers will show CRC=0 if loading the data is successful, on the other hand it shows CRC=1 if data is corrupted/misaligned.
Rohit
Hope it helps.
Harshit
