Compatible SPI Flash memory for XS725
Hi all,
I'm trying to figure out whether it's sufficient to match 'manufacturer family' in UG908, or whether the specific device is required to match. I've currently got a part in the schematic (MX25L3206EM2I-12G) which matches the 'Macronix, mx25l family', but the specific device in the table (pg331) is mx25l3233f, not mx25l3206...
Anyone know if this is "good enough" ? Or am I better off selecting a specific example ?
Cheers
   Simon
Hi @sjg69,
It is not sufficient to match only manufacturer family in UG908 guide. The advise is to go with the Specific device part mentioned in ug908.  some times even if manufacture family is same, some devices are different in density, data width addressing mode which may not supported by xilinx. So better is to go with the specific device part which is mentioned in UG guide.
Best Regards,
Srikanth
Hi @sjg69,
Best Regards,
Srikanth
