Observer jjmax87
Configuration Memory Frames
I have a design which instantiates the SEM IP and also contains a Pblock and I want to inject faults (only) into the Pblock. I have searched the SEM IP product guide and application notes, but I could not find any detailed information about the addressing scheme. It is described, that a linear or pyhsical address can be used, but not how they are mapped to several resources  (CLBs...). Is there any possibility to retrieve the frame addresses for the resources of a certain Pblock?
Thank you in advance,
Kind Regards,
Markus
Scholar pratham
Re: Configuration Memory Frames
@jjmax87 No, you cannot calculate. You can inject error from these address
http://www.xilinx.com/support/answers/65539.html
-Pratham
Observer jjmax87
Thank you! Is there at least a way to figure out which frames are used by my design, without any mapping to resources?
