Configure Spartan 6 after power up
I don't have a lot of experience in the FPGA field.
I'm currently working on a FPGA project with a Spartan 6. The system on wich the FPGA is used will be embedded and powered by a battery.
The problem is that when I will powered down the FPGA, I will lost the configuration. Reconfigure it with the computer each time I power up the FPGA is not practical.
Is there a better way to do it ? I will use it with a microcontroller.
Thank you in advance.
Antoine
Hi @antoiner ,
If you follow any configuration methods apart from JTAG, mentioned in Chapter 2 of UG380 , then there is no need for you to configure FPGA each time from your PC.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
Hi @antoiner ,
Deepak D N
Ok thank you for this document.
But my main problem is : do i need to reconfigure my FPGA each time i power it up ? Is there a way to avoid it ?
Antoine
Most FPGA are RAM based, so the way they work is they have a flash configuration memory and hardware is set up to automatically fetch the configuration from there. It takes a number of ms.
If you really want to avoid that (I can't see why that is a problem) there are Flash-based FPGAs, mostly from Microsemi, but bear in mind your choices will be very limited and their performance is not as great.
Even more alternatives: do you really need to power off? You may be fine by just stopping all FPGA activity.
To echo @archangel-lightworks , the Xilinx FPGAs are RAM based.  If you turn them off, they need to be configured at power on.  You can add a flash memory and configure them from flash.  You could use the micro to configure the FPGA, depending on how it is connected.  Bit-banging from the micro will be a little slower, but not horribly so for a small FPGA.
