saq
Correct Configuration of System Monitor using System management Wizard for Temp_out
I am using Xilinx Virtex UltraScale FPGA (VCU108). After 2 days of trying to configure the SysMon, I can still not figure out why temp_out (10 bit bus) is stuck to 0. I have activated it via wizard and am using AXI4-Lite. I can get ther user temp alarm working but not the bus. Is this a bug? I was not expecting a simple bus to be so complicated, that too while using a management wizard to configure it.
austin
saq,
Do you have the verilog (or VHDL) module to put the data into your registers?  In VU, there needs to be a state machine to read the sysmon through the internal SDI interface from the programmable logic to the sysmon ug580.
Austin Lesea
Principal Engineer
Xilinx San Jose
saq
Thank you for the response. I am running the vcu108_ipi example in Vivado 2016.4. It already has all the components connects. I have only written one additional module that reads temp_out and temp_user_alarm_out. The user alarm is working fine and setting and resetting according to settings but temp_out is always giving a 0 output.
saq
Still having the same problem after regenerating everything and running design from scratch. I am surprised at how hard it is being to run an official example provided by xilinx. I can load the simulation file now by manually pointing to its path but it has not been much useful.
saq
So here are the screenshots of config of the sys management wizard and I have also attached the OP of the ILA. As you can see the last signal is temp_out that is always set to 0. Any ideas what might be causing this?
