cwrigley
Could not find FPGA device on the board for connection local on Diligent ARTY S7 board
Vitis can not upload to ARTY S7-50 board.
cwrigley
Thanks for the help. That solved it!!!
florentw
HI @cwrigley
  • Is the board connected to the same machine as the one used for Vitis (no remote connection)?
  • Do you see a new device in the windows panel control when you plug the board?
Florent
cwrigley
computer is local.
Yes, when plugged in the comport shows up as usb com 6, but that is the com port.
How do we program it? What does that show up as? With impact, you can query the board to see what's there.
Impact can't see this board. I don't know how to use Vivado or Vitis to query the board.
florentw
HI @cwrigley
You can use the same cable as for the UART.
You need to make sure that the following jumper is in JTAG position:
Florent
cwrigley
The jumper is in the JTAG position.
One more note: This ARTYS7 boards works on my Company supplied laptop running windows 10 Enterprise.
The ARTYS7 board doesn't work on my home computer running Windows 10 Home 64 bit. (which the software down load says is not supported)
I payed $130 for a full new install of Windows 10 Pro 64 bit, but when trying to install it, it kept up dating my Home version.
So I called Micro Soft and for only an additional $90 on top of the $130, they remoted to my my machine, flipped one bit somewhere and presto magic, my machine had windows pro, just like that. Amazing.
I haven't' tried uploading again because my Vitis project disappeared.
cwrigley
OK, just tried it again with the Windows Pro 64 bit and it still fails. Same error as before.
hj
Have you installed Digilent JTAG drivers?
C:\Xilinx\Vivado\Vivado_version\data\xicom\cable_drivers\nt64\digilent
Install those and see if this works.
For more information please refer to configuration resources https://forums.xilinx.com/t5/FPGA-Configuration/Configuration-Resources/m-p/753763/highlight/true#M5891
cwrigley
cwrigley
that solved it!
cwrigley
I'm not allowed to add Kudos, sorry
