sy5809358@gmail.com
DEVICE IS DISCONNECTED
Hi,All
when i try to open my vivado 2018.3 hardware manager and connect my zybo board. i got this error.
i notice that it seems usb cable is disconnected when the vivado try to open target and dmesg as  shown below image.
ddn
Hi sy5809358@gmail.com ,
Ensure you are using supported OS for Vivado 2018.3, For more information refer page 16 of UG973.
Ensure you board files are included in Vivado. And there is no issue in power rails of the board.
Try reinstalling the cable drivers by referring page 36 of UG973 (v2018.3). and share the results.
Also share the complete log file.
Deepak D N
Please Kudo or Accept as a Solution, If it helps.
Deepak D N
Please Kudo and Accept as a Solution, If it helps.
ddn
Deepak D N
Deepak D N
sy5809358@gmail.com
thank you.After reinstalling the cable drivers and also i included the boradfiles in Vivado. but i got the same problem.
