12-06-2018 09:46 AM
Using Win10 PRO, 64bit
Platform Cable USB II (DLC10) programmer (green LED is ON).
Trying to use iMpact to program XC2C64A
First tried “Xilinx_LabTools_14.7_1015_1”
iMpact could not recognize cable (searching through support forum: tried to reinstall drivers)
Even though the cable is listed, no luck conencting.
After searching on the support forum, I installed “ ISE Design Suite for Windows 10 - 14.7 “. Virtual machine.
When I try to open my project (*.ipf) – iMpact error out (see screen shot below)
When I try to add XILINX device and open my (.jed) – error: Failed: iMPACT :2855 (see screen shot below)
Cable OK
trying to open project ( .ipf)
trying to ADD DEVICE (.jed)
Chip scope does find my chip, so I am pretty sure the DLC10 is fine…
Do I need to start looking for win7 computer?
What am I missing?
thanks
12-06-2018 08:33 PM - edited 12-06-2018 08:39 PM
Hi @pavel_s
As @hj mentioned Xilinx ISE 14.7 and IMPACT 14.7 Lab tools are not officially supported for Windows 10. So, you need to use workaround provided at https://www.xilinx.com/suppor t/answers/62380.html for Xilinx ISE 14.7 to make it work on Windows 10 platform.
To make work IMPACT 14.7 Labtools in Windows 10 try below workaround:
Download Xilinx ISE 14.7 and IMPACT 14.7 Lab tools from https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/v2012_4---14_7.html
Important : Above workaround works directly on Windows 10 machine, you need to install IMPACT 14.7 on Windows 10 machine (not in VM)
12-06-2018 12:59 PM
Windows 10 ISE only for spartan 6. If you are using any other device then please use ISE (Windows 7) version.
Yes Please try to install ISE on Windows 7 machine. It will resolve the issue. You can download it from here https://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools/v2012_4---14_7.html
12-06-2018 01:42 PM
12-06-2018 01:44 PM
Which device you are currently using? Currently ISE (windows 10) only supports Spartan 6.
Hi @pavel_s
12-07-2018 10:57 AM
Bhushan;
this worked.
Thanks!
10-24-2019 03:21 AM
Hello bpatil,
This fix for the DLC10 Platform Cable USB II Programmer worked really well on my Windows 10 machines up until about a few months ago. After a few Windows 10 automatic updates, the work-around with the .dlls no longer works. I'm currently running Win 10 Pro version 1903 (OS 18362.418).
I have the Spartan-6 SP605 board and numerous other custom boards with Spartan-6 devices. At the moment I am unable to program any of them in ISE 14.7. Are there any new fixes available? The SP605 board is still actively being sold by Xilinx, so there should be a solution out there. Can you help?
01-19-2020 02:54 AM
01-20-2020 11:43 AM
Thanks for your response. Yes, I've come to the conclusion that the _only_ sure way to run ISE 14.7 (and all related ISE tools) is to run the 'virtual machine' version. It's not a great solution and it's a lot of overhead but I suppose it's the only option we have now for 6-series FPGAs and below ...
