Delaying an incoming signal
What is the best way to delay an incoming signal so as to have a lot of very repetitive (ideally always equal) delay through a great number of stages? And this delayed signal should be able to be latched by e.g. flip-flops along the delay line. Like in various TDC schemes, for instance.
Do you want to delay by an integer number of clocks?  Then this technique might work for you.  A fractional number of clocks?  Then look up the IDELAYE2 primitive.  A fractional number of clocks?  Then you might need to do some form of sub-sample interpolation.
Dan
Hi Dan,
It is a fractional number of clocks or even a smaller delay.
I'll look up the IDELAYE2 primitive indeed, thanks.
How do you perform a sub-sample interpolation?
Ermanno
To be more precise, the delay I'm looking for is some tens of picoseconds.
@Ermanno,
Look up the IDELAYE2 primitive then.
As for interpolating fractional delays, that works more on samples than on logic.  You can read some of the theory behind it here--together with finding some examples of how to do it in the same repo.
Dan
