Difference between vivado and ISE flash checksum calculation
Hiii,
I am using both ISE and Vivdo for my projcet developement. The configuration flash Readback checksum and prom checksum are different in ISE, but in vivado both are same.. why or how this is going on????
Re: Difference between vivado and ISE flash checksum calculation
Hi murali@1996 ,
In ISE tool,
the Impact uses different algorithm to calculate Checksum for Flash device and PROM checksum files are provided by PROMGen tool. That is the reason they both are not matched in ISE.
When it comes to Vivado, User generates cfgmem file and specifies -checksum write_cftmem option. This step creates
the .prm files that contain checksum information about the cfgmem output file.
Best Regards,
Srikanth
Hi murali@1996 ,
In ISE tool,
Best Regards,
Srikanth
You can also refer to following AR https://www.xilinx.com/support/answers/18884.html
-Harshit
