Observer tamiro
Different Results Running TCL Script In Flow vs. Manually - SPI Flash burn workaround
I use the workaround describe at:
"(SR#10397755) IS25LP064 as a boot flash for Artix 7"
To burn Micron N25Q 1 Gb flash with configuration of Artix7.
When I prompt the commands manually at the tcl console - all works well.
When I run them by a tcl script, All runs until the command "xspi_prog_data"
It starts OK
prints:
Entering 4 byte address mode
Programming data file ...
Programming start address = 0 [0x00000000]
Programming page[0] = 256 of ...
but then it doesn't continue.
If I stop the tcl script and write the same command manually It works fine.
It seems like it runs much much slower If called from the tcl script.
Do you know why the command will behave differently when sourced from a tcl script or when prompt manually?
Tami.
Visitor lumoti
I have the identical problem. Please help!
