betontalpfa
Digilent programming-cable - Done pin is not high
We have problem programming FPGAs using Digilent programming-cable. Some of our (custom) board can be programmed, some cannot, but all of them can be programmed with standard Xilinx Blaster.
The following error comes up (in some cases with the Digilent cables), at the end of the programming: Done pin is not high.
So: The Digilent cable does works in some cases (with some boards) and all of our boards can be programmed in a way (with Xilinx Blaster). What can be the root-cause the programming problem of the Digilent cable and the boards?
We have reduced the JTAG clock frequency, but we see the same error.
Benedek
betontalpfa
We have inserted a schmitt trigger clock buffer, in the TCK clock line. Now, everithing is fine.
Benedek
u4223374
Advisor
Advisor
Which FPGAs?
The HS3 isn't compatible with some of the really old ones, but any reasonably modern FPGA should work.
Might be worth posting this on Digilent's forums, since it seems to be an issue with a Digilent product.
drjohnsmith
good first startt lowering the JTAG speed,
Its unclear are these boards all the same design, and some can be programed with HS3 and some cant,
   or are they different board designs ?
betontalpfa
The FPGA Device is Zynq-7000, xc7z030sbg485-2.
The boards are different pieces (S/N) of the same product.
Benedek
drjohnsmith
So if some can be programmed, its not incompatibility.
Out with the scope,
check the JTAG chain,
Im wondering if some of the boards have faults,
betontalpfa
Benedek
drjohnsmith
looks like you had signal integrity problems,
its normal to put terminator and / buffering on the JTAG lines,
https://www.xjtag.com/about-jtag/design-for-test-guidelines/
