EEPROM application using GPIO
Hey all,
I want to read and write in eeprom using microblaze .For that i have taken GPIO as IO port .and write a code into microblaze.
When i am going to  run it.it neither write nor read. I used ILA and in that always getting SDA and SCL high.
How to do it using GPIO .
Do I understand you have a I2C EEPROM ?
did you remember to add the pull up resistors on the I2C lines ?
Out with oscilloscope and probe the real lines,
I'm guessing your "bit banging" the I2C ,
This is not your problem, but will be.
I2C was originally "designed" for a nice symmetrical clock,
yes later i2C added pulse stretching, but its implementation i devices is , in my experience , patchy,
Most all , certainly all the ones I have seen, do not bit bang I2C , but use a I2C master, and the processor talks to that in the FPGA much like it would to a UART.
There are plenty of I2C cores around, many for free,
for example
https://www.xilinx.com/products/intellectual-property/axi_iic.html
Thanks for reply
Yeah I am using I2C EEPROM.
I have checked in schamatic ..pull up resistors  are there on I2C line.
When i am probing on osilloscope then on scl pin i am getting the pulse but SDA line is always high.
with SDA always high, you are not getting a start ./ stop on the I2C.
Hey,
Thanks for reply.
Yes i am not getting the start condition as i have called the write_start function but then i am not getting anything on SDA pin but on scl it becomes low  .
void EEPROM_WriteStart_Condition(void)
MAKE_CLK_PIN_HIGH()                               // make CLK pin high
Configure_Pin(SDA,OP_PIN);                       // This function will configure SDA pin as OP pin
MAKE_SDA_PIN_HIGH()                             // make SDA pin high
Delay_uSec(3);                                             // This function will introduce 3 microsecond delay
MAKE_SDA_PIN_LOW()                            // make SDA pin LOW
MAKE_CLK_PIN_LOW()                           // make CLK pin LOW
return;                                                       // go back to caling function
If it simulates OK, then you have a board problem,
But that code , with things like delay_uSec(3) looks terrible, how are you going to garuntee the delay in a processor ?
@drjohnsmith Thanks for reply..
Suggest me instead of delay what i can use?
Use a I2C block that handles the I2C for you ,
and looks like a UART to the processor.
