10-16-2014 02:47 PM
Hi guys,
I am able to program my Virtex-5 FPGA using JTAG and I am able to do that successfully now. However, I'm also using a M25P64 on the custom board and I tried using the Indirect SPI Method of Programming the Flash Memory but I'm getting an error when programming it. I've pasted the errors below:
// *** BATCH CMD : Program -p 1 -spionly -e -v -loadfpga
PROGRESS_START - Starting Operation.
Maximum TCK operating frequency for this device chain: 33000000.
Validating chain...
Boundary-scan chain validated successfully.
1: Device Temperature: Current Reading: -273.00 C
1: VCCINT Supply: Current Reading: 0.000 V
1: VCCAUX Supply: Current Reading: 0.000 V
'1': IDCODE is '202017' (in hex).
'1': ID Check passed.
'1': Erasing Device.
'1': Using Sector Erase.
'1': Programming Flash.
'1': Reading device contents...
Failed at address, 0
'1': Verification Terminated
INFO:iMPACT - '1': Flash was not programmed successfully.
PROGRESS_END - End Operation.
Elapsed time = 147 sec.
I did a Readback and it did that without any issues.
INFO:iMPACT - Current time: 10/16/14 3:19 PM
// *** BATCH CMD : ReadbackToFile -p 1 -file ".mcs" -spionly
Validating chain...
'1': Performing readback on device...
'1': Readback completed successfully.
Elapsed time = 590 sec.
Is there an specific Application Note for Indirectly Programming using SPI for the Virtex-5 ? I only found an application note for the Spartan series FPGA. Let me know if any more information is needed.
10-16-2014 02:52 PM
You say "I did a Readback and it did that without any issues," but what was in the data that got read back? Did it actually match the data you wrote? If not, I would start to suspect that the device erasure isn't working. There could be a number of reasons for that, but you could start by trying to erase and blank check the device using Impact. If you can't get that to work, then there is an erasure issue.
10-16-2014 03:19 PM
Actually, I haven't written any data to it at all. This is the first time I'm programming it and it hasn't been programmed yet. Its just the Programming which fails. But I'm able to perform the other checks such as Erase and Blank Check
INFO:iMPACT - Current time: 10/16/14 4:35 PM
// *** BATCH CMD : Erase -p 1 -spionly
Validating chain...
'1': SPI access core not detected. SPI access core will be downloaded to the device to enable operations.
INFO:iMPACT - Downloading core file /opt/Xilinx/14.4/ISE_DS/ISE/virtex5/data/xc5vfx70t_spi.cor.
'1': Downloading core...
Match_cycle = 0.
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0011 1111 1011 1110 0000 1010 1000 0000
INFO:iMPACT:2492 - '1': Completed downloading core to device.
Elapsed time = 67 sec.
INFO:iMPACT - Current time: 10/16/14 4:36 PM
// *** BATCH CMD : BlankCheck -p 1 -spionly
Validating chain...
'1': Performing blank check on device...
'1': Part is blank.
Elapsed time = 234 sec.
10-16-2014 06:51 PM
Your original post seems to say that you've tried to program the flash:
So the question is what ended up in the readback file? Was it all 0xFF indicating that the flash was still blank after the attempt to program? And what version of the ISE lab tools are you using?
10-23-2014 10:01 AM
I tried reprogramming the Flash without the Verify step and this is what I get:
INFO:iMPACT - Current time: 10/23/14 11:53 AM
// *** BATCH CMD : Program -p 1 -spionly -e -loadfpga
Validating chain...
Match_cycle = 0.
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1':Programming in x1 mode.
'1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings.
Elapsed time = 240 sec.
I'm not sure how to do a comparison between the file I loaded and what I read back from it. I'm using ISE 14.3
10-23-2014 10:19 AM
I'm not sure if the bit file is being correctly loaded onto the Flash Memory. I've pasted the first few lines of the simple_flash_1.mcs (PROM file loaded) and the simple_flash_1_readback.mcs (Readback file)
simple_flash_1.mcs
:020000040000FA
:10000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00
:10001000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
:10002000000000BB11220044FFFFFFFFFFFFFFFFA6
:10003000AA9955662000000030020001000000006F
:10004000300080010000000020000000300080012E
:100050000000000720000000200000003002200106
:1000600000000000300260010000000030012001AB
:1000700002003FE53001C0010000000030018001B6
:10008000032C609330008001000000092000000074
:100090003000C001004000003000A001004000001E
:1000A0003000C0010000000030030001000000002B
:1000B00020000000200000002000000020000000C0
:1000C00020000000200000002000000020000000B0
:1000D000300020010000000030008001000000011D
:1000E0002000000030004000500CE1F00000000053
:020000040000FA
:10002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
:10003000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
:10004000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
:10005000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
:10006000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
:10007000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
:10008000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80
:10009000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70
:1000A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
:1000B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
:1000C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40
:1000D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
10-26-2014 06:06 PM
Anyone know what might be causing the issue ?
12-01-2014 01:50 AM
