Visitor dh0414.lee
Error messages while Auto Connect after program device
I create DDR4 MIG IP in VIVADO project and edit source.
Edit source contents is BYPASS_CAL = "FALSE" to BYPASS_CAL = "TRUE".
And I succes to make a Bitstream.
After program device, I got to errors
[Xicom 50-38] xicom: invalid string position
[Labtools 27-3176] hw_server failed during internal command.
Resolution: Check that the hw_server is running and the hardware connectivity to the target
My system is windows10, VIVADO 18.2
Please, anyone give me the solution.
Re: Error messages while Auto Connect after program device
Hi @dh0414.lee
Are you able to configure FPGA with simple design (like counter ..) with current setup?
After connecting programming cable does device driver detects driver for cable? Share screenshot.
Which programming cable you are using?
Bhushan
回复: Error messages while Auto Connect after program device
Is your OS an English version OS or some other language OS?
If you can download a simple design bit without any problem, this seems to be an OS issue.
