kbj1213
FPGA Schematic Datasheet
Hi, I bought the XCKU115 - FLVA2104 - 2 FPGA.
Is there any way I could get the schematic datasheet which include all information of I/O pins?
I found the text file which Xilinx supports(https://www.xilinx.com/support/packagefiles/usapackages/xcku115flva2104pkg.txt), but couldn't schematic pdf file.
bruce_karaffa
Did you buy just a chip or a board with an FPGA mounted on it?  If you bought a board, search for the schematic in the documentation for the board.  If you bought just the FPGA, there is no schematic.  The FPGA can be configured many different ways.  It is up to you to determine which signals go to which pins.  There are many rules you must follow when doing this, but the connections are still up to you.
iguo
What did you mean by schematic pdf file? Are you looking for a reference board design or something?
If yes, refer to this:
https://www.xilinx.com/products/boards-and-kits/dk-u1-kcu1500-g.html#documentation You can see the board schematic there.
