arunjadhav
HARDWARE TARGET DETECTED BUT DEVICE NOT FOUND VIVADO 2016.1 (ARTIX-7 FPGA)
Hi all,
This is a Artix-7 based custom board where when we power on the board the JTAG led gets green & further the hardware target gets detected but no device is found. Vivado 2016.1 is used here.
Checked points:
1. All FPGA configuration related voltages.
2. JTAG (TCK,TMS,TDI,TDO) signals voltage levels & behaviour
Kindly suggest further debugging steps.
Arun
emy
Set the JTAG clock frequency to lower frquency and try it
arunjadhav
Tried with 750KHz
But the issue still persists.
drjohnsmith
out with the scope,
follow the JTAG lines, see where the waveform stops,
    you should be able to see the training waveform of JTAG through the loop, and you should see a nice clean signal on al llines.
this is form the old tools, but still relevant
https://www.xilinx.com/support/documentation/sw_manuals/xilinx14_6/pim_r_common_issues_and_debug_solutions.htm
and these guys know a good thing or three
https://www.xjtag.com/support/support-notes/jtag-chain-debugging/
arunjadhav
Will check & update
arunjadhav
On debugging with IMPACT Boundary Scan Chain Debug,
We noticed that the TDO pin is not responding as per the TDI input. TDO is constantly high.
Also in this hardware, VCC_INT voltage was not reaching FPGA and we switched on the board. As a result of which power sequencing was violated. So we want to know that is this the reason for the TDO not responding & the FPGA device not getting detected. Do we need to replace the FPGA?
Please suggest
drjohnsmith
you might be luck with the FPGA , just connect vcc_int, though I would not ship the boar to customer,
yep, I think the JTAG runs off the vcc_int lines
arunjadhav
TDO line was not connected properly. So looks like that's not the issue.
But its true that the VCC_INT voltage was not supplied initially. So the power sequencing was violated.
Please suggest how to proceed.
Thanks in advance
drjohnsmith
fix it and see what happens
arunjadhav
Even after fixing it ..the FPGA is not getting detected ..
Any suggestion.?
drjohnsmith
did you pop the fpga is an option ?
does the tdi / tdo trace following with the scope now work ?
