Participant lanxiang.ben
How to constraint BPI flash pin of FPGA when controlling BPI flash by user logic?
Hi All
    Refer to 《ug470_7Series_Config.pdf》,I know that "After configuration is DONE,these pins become user I/Os and can be controlled by user logic to access BPI flash for user data storage and programming."(Page 127).Now, I want to do it, The flash is used for configure FPGA (MCS file) original. After Synthesis and Implementation, There are some errors during Write Bitstream as ancessory, So I want to know:
(1) Can I constraint my user logic port to these FPGA pins?Refer to ug470,I think it should be. But I still want to confirm it.
(2) How to constraint this pins?
    Circuit diagram and .xdc file were shown as follow.
BR
lanxiang
Re: How to constraint BPI flash pin of FPGA when controlling BPI flash by user logic?
the flash interface multipurpose pins can be used as normal i/o's, since you want to read and write after configuration you will need to declare this pins in the xdc file with the required i/ostandard of the flash.
--Krishna
