How to delete a Design internally
Hi All,
I'm designing a secure system with verilog. Can I delete My design files (bitstream files from FPGA board) internally with verilog? If possible how it could be done? Any information is appreciated.
Thanks in advance.
Hi vmerter,
Are the bit files on a Flash PROM (such as SPI or BPI) or only on the FPGA?
When you power down an FPGA, it loses its configuration. If you want to erase a Flash PROM, that can be done, too.
Andres
hi @vmerter,
I believe and assume you wanted to deleted or format  the bitstream(.bit file ) through the Verilog code  which is inside the FPGA once it is configured unfortunately  this is cannot be done.
if I have answered your query , please close this forum by accepting the solution. if not please let me know your inputs
Chandra
Chandra sekhar
Kindly note- Please mark the Answer as "Accept as solution" if solution provided is helpful.
Hi vmerter,
Andres
