How to generate mcs file by vivado
vivado version: 2013.4
FPGA version: v7
After generate bit file, how to transfer it into mcs format, which can be loaded into flash chip?
Re: How to generate mcs file by vivado
vivado 2013.4 cannot generate prom files.
You will need to use 2014.1 vivado
check the following command for spi flash
write_cfgmem -format mcs -interface spix4 -size 128 -loadbit "up 0x0 c:/main.bit" -file main.mcs
--Krishna
You could use the ISE Design Suite PROMGen tool to create PROM files"
Write_cfgmem is the Vivado equivalent.This will be fully supported from Vivado 2014.1.
Hope this helps.
Sikta
Hi kkn,
Thank you for your reply.
From vivado Tcl Console, I input the command, but it can't be suportted.
write_cfgmem -help
invalid command name "write_cfgmem"
Where the command can be input?
Thx more!
Which version of tools are you using? This is only supported from 2014.1.
Please check this user guide(page-1246)
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug835-vivado-tcl-commands.pdf
Hope this helps.
Sikta
Hi siktap,
The  PROMGen tool in ISE, do you mean Impact?
Open IMpact, I want to generate spi flash file(mcs). At step of choose correponding bit file, there is an error like:
The specified file is nota Spartan6/sparten3e/3a/3an or virtex5/virtex6 file. Please select another file.
So if the impact can not support v7 series?
hi siktap,
the vivado version is 2013.4.
If I don't re-setup the newest vivado version, then how can I do next?
Thanks again
Community Manager
Community Manager
Hi Jenny,
For all the users who are using earlier versions of 2014.1, the recommended way to generate the .mcs file from .bit file is to use promgen.
The promgen command comes integrated with impact.
Please note that impact is a free tool and doesn't need any license.
Krishna
In that case, you have to use promgen. Please see if this helps.
http://www.xilinx.com/support/answers/23174.htm
You should find it in the Lab Tools in the following directory.
C:\Xilinx\14.7\LabTools\LabTools\bin\nt
Sikta
Hi siktap,
The website link can't be read normally? I haven't seen any info about promgen tools.
And in my directory of ISE, I haven't found LabTools.
Hi Jenny
Promgen is not included in the Vivado installation.
It says that it is available in the Lab Tools which is a relatively small 1GB installation compared to the full ISE Suite
http://www.xilinx.com/support/answers/54939.html
Sikta
Hi smarell,
How to open promgen command?
I tried generate mcs file through impact, but it failed,  It seems the impact tools can't read v7 bitstream, isn' it?
Community Manager
Community Manager
Hi Jenny,
Impact tools can recognize 7-series bit files.
There shouldn't be any problem in generating the mcs file.
What error are you seeing in impact?
Krishna
Community Manager
Community Manager
Follow the steps given in http://www.xilinx.com/support/documentation/sw_manuals/xilinx13_1/pim_p_creating_prom_file_xilinx_prom.htm
Hi smarell,
The info like:
Community Manager
Community Manager
Which device are you targeting? Can you attach the bit file here?
Hi smarell,
I use SPI Flash not Xilinx Flash.
It it is ok?
Community Manager
Community Manager
Yes that should be ok. Which version of impact are you using?
Hi smarell,
FPGA : xc7v585t.
The bit file is 19M.
Which info do you want?
Hi smarell,
The impact version is 0.40d
I've found easy way to generate mcs file within vivado.
Write to tcl-console the following command:
cd [get_property DIRECTORY [current_project]]/[current_project].runs/impl_1
write_cfgmem -format mcs -interface bpix16 -size 32 -loadbit  "up 0 [get_property top [current_fileset]].bit"  -file Untitled.mcs -force
 You can change it for your case, but it should match for most of them.
